[GUÍA][RECOVERY][MI3 CDMA] ClockworkMod 6.0.3.7 for Xiaomi Mi3 tegra4 (pisces)
Cuando tenga un respiro lo traduciré. Está sacado de XDA (No tienes permisos para ver los enlaces. Regístrate o Inicia sesión). Esto solo sirve para las versiones que no son WCDMA ;)
This is a modified ClockworkMod recovery for the Xiaomi Mi3 tegra4 (pisces). It includes some changes from M1cha's CWM for Mi2 to support the dual-system design of the Mi2 (same thing on Mi3), while leaving out "true dualboot" feature for now. I think TDB is useless as long as there is only MIUI available for this device. See source for details.
Working so far:
  • adbd in recovery
  • nandroid backup/restore, including system1, boot1
  • running any update.zip (including AROMA)
  • choose system to install update to
  • set active system
  • Anything else untested.
Installing:
  • Flash using fastboot:
adb reboot-bootloader
{wait for fastboot screen}
fastboot flash recovery cwm-*-pisces-*.img
  • Boot new recovery:
Type fastboot reboot and press enter while holding Vol+ key should take you directly to CWM.
  • Let CWM disable recovery flashing (offered automatically when selecting reboot)
I didn't test this method so far (feedback welcome) -- in case it doesn't work, try this instead:
    Alternative installation method:
    • Disable automatic recovery reflashing (while running MIUI, requires busybox installed and a root shell, eg "adb root; adb shell")
    mount -o remount,rw /system
    chmod 444 /system/etc/install-recovery.sh
    mount -o remount,ro /system
    adb reboot-recovery
    {wait for fastboot}
      Instalación de este CWM Recovery via MiRecovery:
      Para facilitar su instalación hemos construido un zip con el CWM Recovery para el Mi3 Tegra4, que ya va renombrado a update.zip tan solo tienes que copiarlo desde el PC a tu dispositivo e instalarlo via MiRecovery:
      : update.zip > No tienes permisos para ver los enlaces. Regístrate o Inicia sesión
      « Última modificación: 10 de Agosto de 14, 11:43:53 am por juliusssss »
      Re:[GUÍA][RECOVERY][MI3 CDMA] ClockworkMod 6.0.3.7 for Xiaomi Mi3 tegra4 (pisces)
      « Respuesta #1 en: 23 de Enero de 14, 15:42:28 pm »
      Reservado
      Desconectado erchupa
      « Respuesta #2 en: 28 de Enero de 14, 09:27:13 am »
      Este es diferente que el de miui.it? En que se diferencian?
      Enviado desde mi MI 3W usando Tapatalk 4
      « Respuesta #3 en: 28 de Enero de 14, 09:50:10 am »
      Imagino que este es para el  Tegra4 (versión China) y el otro es para la versión WCDMA ;)
      « Respuesta #4 en: 28 de Enero de 14, 11:02:08 am »
      fallo mio al leer el titulo, le añadi una w  ::)
      Desconectado seraran
      • Votados: 10
      « Respuesta #5 en: 30 de Julio de 14, 12:38:19 pm »
      Hola
      Alguien sabe como se instala este recovery, tengo un Mi3 TD y necesito instalarle un CWM
      Saludos y Gracias
      « Respuesta #6 en: 31 de Julio de 14, 12:04:51 pm »
      Hola
      Saludos y Gracias
      Hemos construido un zip con el CWM Recovery para el Mi3 Tegra4, ya va renombrado a update.zip tan solo tienes que copiarlo desde el PC a tu dispositivo e instalarlo via MiRecovery:
      Actualizado primer post añadiendo este sistema de instalación.
      « Última modificación: 31 de Julio de 14, 12:08:56 pm por redber »
      Desconectado valldeuxo
      « Respuesta #7 en: 04 de Octubre de 14, 18:39:50 pm »
      hago todo lo que dices, en mi terminal  tengo instalado android system recovery 3e, y intento instalar el update que has puesto, ycuando lo hago me sale
      install/sd card
      error invalid ota package.missing scatter
      installation aborted
      gracias
      « Respuesta #8 en: 04 de Octubre de 14, 18:44:13 pm »
      por cierto intento entrar en modo fastoot , o sea volumen abajo y encendido, y solo me sale una fotocopia de un coche, y no me deja hacer nada mas, solo me queda apagar el terminal.
      alguien sabe si es normal esto que en este modo  salga un coche y no deje hacer nada
      gracias
      « Respuesta #9 en: 04 de Octubre de 14, 19:09:45 pm »
      gracias
      Comprueba que no sea una falsificación: No tienes permisos para ver los enlaces. Regístrate o Inicia sesión
