[ROM] [MIUI6][4.4][v5.7.2][OFICIAL] Redmi Note (4G/Qlcmm)(1sim) - Codename: (Dior)
  • Votados: 2984
AVISO
RECORDATORIOS
Cómo activar Google Now
INSTALACIÓN DE LA ROM
  • Tener claro que corresponde a mi modelo, ésta es para el Xiaomi Redmi NOTE 4G LTE/W, instalarla en otro modelo posiblemente lo brickees
  • Comprobar en Ajustes > Acerca del teléfono que en modelo indica "HM NOTE 1LTE"
Aquí Redber lo explica muy bien No tienes permisos para ver los enlaces. Regístrate o Inicia sesión, os dejamos un resumen a continuación.
Los Wipes con MiRecovery
Wipe Cache:
Wipe Data:
Wipe All Data:
Esta ROM ¿lleva ROOT?
AVISO:
  • Votados: 2984
Re:[MIUI6][4.4][v5.7.2][OFICIAL] Redmi Note (4G/Qlcmm)(1sim) - Codename: (Dior)
« Respuesta #1 en: 08 de Julio de 15, 23:14:29 pm »
Changelog 5.7.2 - No tienes permisos para ver los enlaces. Regístrate o Inicia sesión
ORIGINAL en Inglés
Spoiler for Hiden:
[Phone]
Optimization - Unified animation effects of folding/unfolding T9 dial pad (07-01)
[Contacts]
Fix - FC error or no response issue when calling back/replying messages to unknown numbers (06-26)
Fix - Marking unknown numbers might cause FC (07-01)
[Messaging]
New - SMS syncing status will be displayed when pulling down on SMS list page (06-29)
[Lockscreen, Status Bar, Notification Bar]
Optimization - Use standard Android notification style for USB connection (06-29)
[Home screen]
Fix - Global search could rotate upside down when screen rotate was disabled (06-29)
[Gallery]
Optimization - Adjusted Mi Note Gallery to display four images in each row (06-26)
Fix - Sometimes browsing large images in People album caused FC error (06-30)
Fix - People albums' covers did not update timely (06-30)
Fix - Videos taken with screen locked could not be played normally (06-30)
[Music]
New - Added music copyright information in Settings page (06-29)
[Weather]
Optimization - Do not allow to pull down to refresh again during the process of refreshing (06-29)
[Settings]
New - Users can mark if a WLAN is mobile hotspot after connecting to it (06-30)
[Security]
New - Added monthly report feature to summarize monthly security status of device (06-30)
ORIGINAL en Español (Traducido gracias a "kayron_8")
[Teléfono]
Optimización - Efectos de animación del teclado desplegable T9 unificados (07-01)
[Contactos]
Corregido - FC o problema de respuesta al devolver la llamada/responder mensajes a números desconocidos (06-26)
Corregido - Al marcar números desconocidos podría causar FC (07-01)
[Mensajes]
Nuevo - El estado de la sincronización de los SMS se mostrará cuando se avance hacia abajo en la lista de SMS (06-29)
[Pantalla de bloqueo, barra de estado, barra de notificaciones]
Optimización - Ahora se usará el estilo estándar de notificación de Android para la conexión USB (06-29)
[Pantalla inicial]
Corregido - La búsqueda global podría girar al revés cuando se ha desactivado la rotación de pantalla (06-29)
[Galería]
Optimización - Adaptada la galería del Mi Note para visualizar cuatro imágenes en cada fila (06-26)
Corregido - A veces al navegar por imágenes grandes del álbum Gente podría causar FC (06-30)
Corregido - Las miniaturas del álbum Gente no se actualizan a tiempo (06-30)
Corregido - Los vídeos grabados con la pantalla bloqueada no se podían reproducir normalmente (06-30)
[Música]
Nuevo - Se agregó información sobre los derechos de autor en la página de Configuración (06-29)
[Tiempo]
Optimización - No se permitía avanzar hacia abajo para actualizar de nuevo durante el proceso de refresco (06-29)
[Ajustes]
Nuevo - Los usuarios pueden marcar si una red wifi es un punto de acceso móvil después de conectarse a ella (06-30)
[Seguridad]
Añadida función de informe mensual para resumir el estado de seguridad mensual del terminal (06-30)
  • Votados: 2984
« Respuesta #2 en: 08 de Julio de 15, 23:15:14 pm »
MD5: d776fe5e8f68ea4cb48856d375e32f67
Desconectado jokerspider
« Respuesta #3 en: 09 de Julio de 15, 02:43:45 am »
Instalada sin problemas con dalvik caché y caché. La grabación de vídeo sigue igual que en anteriores, tengo que matar google now para que funcione.
Mañana veré más cosas.
Muchas gracias
Desconectado mariodt
« Respuesta #4 en: 12 de Julio de 15, 21:49:33 pm »
 Gran trabajo chicos, muy buena ROM, todo perfecto, la única pega es que para que te notifique los mensajes de whatsapp tienes que tener la aplicación abierta
« Respuesta #5 en: 12 de Julio de 15, 21:57:01 pm »
Tienes que darle permiso en ajustes/notificaciones/manage notificaciones//whatsapp/notificaciones flotantes
 Enviado desde mi HM NOTE 1LTE usando MiCenter
« Última modificación: 12 de Julio de 15, 22:02:03 pm por jokerspider »
« Respuesta #6 en: 13 de Julio de 15, 17:28:18 pm »
Gracias compi!!! Solucionado jeje
Desconectado palinhas
    • Radiomodelismo Campo Maior
« Respuesta #7 en: 05 de Agosto de 15, 21:03:17 pm »
Ola tengo um problema un tanto raro ...
Me llego ayer de Greekvida mi XIAOMI Redmi Note 4G LTE con la ROOM  MIUI 16.5.2.0 ( KHKCN) Stable
Dandole al recovery como toda la vida intente poner la ROOM miuies_Redmi_Note_4G_1sim_HMNoteLTE_dior_5.7.2_v6_4.4
Pero me passo algo mui raro:
Vale pues con el Mi Pc Suite en fastboot me quede con esta version:
Le doi otra ves al recoveri con la ROM b]miuies_Redmi_Note_4G_1sim_HMNoteLTE_dior_5.7.2_v6_4.4[/b]
e me passa esto:
Mui raro no ? Alguna idea ?
« Última modificación: 05 de Agosto de 15, 21:31:10 pm por palinhas »
