[ROM] [MIUI6][4.4][v5.5.22][OFICIAL] Redmi Note (4G/Qlcmm)(1sim) - Codename: (Dior)
AVISO
RECORDATORIOS
Cómo activar Google Now
INSTALACIÓN DE LA ROM
  • Tener claro que corresponde a mi modelo, ésta es para el Xiaomi Redmi NOTE 4G LTE/W, instalarla en otro modelo posiblemente lo brickees
  • Comprobar en Ajustes > Acerca del teléfono que en modelo indica "HM NOTE 1LTE/W"
Aquí Redber lo explica muy bien No tienes permisos para ver los enlaces. Regístrate o Inicia sesión, os dejamos un resumen a continuación.
Los Wipes con MiRecovery
Wipe Cache:
Wipe Data:
Wipe All Data:
Esta ROM ¿lleva ROOT?
AVISO:
Re:[MIUI6][4.4][v5.5.22][OFICIAL] Redmi Note (4G/Qlcmm)(1sim) - Codename: (Dior)
« Respuesta #1 en: 27 de Mayo de 15, 07:38:44 am »
Changelog 5.5.22 (No tienes permisos para ver los enlaces. Regístrate o Inicia sesión)
[System]
Fix - Charging notification light did not work (05-21)
[Phone]
New - If a call from a unknown number is hung up shortly after it is taken, a prompt will show to ask if you would like to report that number (05-20)
[Contacts]
Fix - Lagging/ FC errors when importing or deleting SIM card contacts (05-21)
Fix - FC error caused by using single quotation marks when searching (05-21)
[Messaging]
Fix - Mi Band 'Vibrate for notifications' feature did not work after receiving a MMS (05-20)
Fix - Messaging app would stop responding if there were too many receipts when sending group messages (05-20)
[Lockscreen, Status Bar, Notification Bar]
New - Added hotspot icon in status bar when portable hotspot is enabled (05-19)
New - Added charging icon in status bar (05-19)
New - Support displaying virtual network operators' names (05-19)
Optimization - Optimized status bar icons' color contrast (05-20)
[Themes]
Fix - No response after booting up for some Redmi devices (05-20)
[Gallery]
New - Added video album to help manage all videos on your device (05-21)
Optimization - Loading speed when opening large images in cloud albums (05-21)
Optimization - Reduced RAM usage when viewing large images (05-21)
Optimization - Enhanced speed of entering Gallery from Camera (05-21)
Optimization - Enhanced smoothness when scrolling in front page (05-21)
Optimization - Loading speed of Offline page (05-21)
Optimization - Modified setting password icon in secret album page (05-21)
Fix - Random FC errors when viewing images in start page (05-19)
Fix - Layout error when choosing several images to add to cloud albums (Mi Note) (05-21)
Fix - Gallery had a high CPU occupancy after booting up (05-21)
Fix - Sometimes, deleting offline albums caused FC error (05-21)
[Weather]
Fix - Sometimes, weather animations displayed abnormally (05-19)
[Settings]
New - Added transition animation when connecting WiFi (05-21)
Fix - Sometimes, incorrect WiFi password prompt did not show after a long time (05-21)
[Market]
New - Brand new MIUI App store (05-18)
New - Most installed app is list first in searching result page (05-18)
Optimization - Optimized searching result page UI style in special situations (05-18)
Optimization - Optimized the prompt when failed to install some apps due to lack of system module (05-20)
Fix - Sometimes Feedback page had FC error (05-18)
[File Explorer]
Fix - Lagging issue when loading thumbnails (05-21)
[Clock / Calculator]
Fix - UI display error when using large font (05-19)
[Mi Cloud]
New - Alarm clock settings can be restored from Mi Cloud when switching to new devices (05-19)
New - New Mi Cloud membership system. Allow users to choose from three membership levels (05-20)
Optimization - Optimized Mi Cloud settings page (05-19)
INSTALACIÓN AVISO
  • Si vienes de una versión anterior a la 5.4.17, es TOTALMENTE necesario hacer WIPE ALL DATA, o sea instalación nueva. (No es recomendable restaurar backup de system, puede dar problemas.)
  • Si vienes de la versión  5.4.17 o posterior, solo con hacer un WIPE CACHE, valdría.
Cambios respecto a la versión anterior
  • Corregidas varias traducciones
  • Se han añadido nuevos iconos meyoueye
« Respuesta #2 en: 27 de Mayo de 15, 07:39:14 am »
MD5: 8247d5a6292382894bef59efb732f4aa
Desconectado euphonico
« Respuesta #3 en: 28 de Mayo de 15, 14:17:29 pm »
Pillo sitio... Descargando. Comentare en breve. Gracias chicos!!
Desconectado ivanhr85
« Respuesta #4 en: 29 de Mayo de 15, 09:26:15 am »
tengo el siguiente problema y no se lo teneis vosotros tambien,cuando me yaman descuelgo y la pantalla se pone en negro y a la hora de colgar no se me enciende la pantalla,hasta que no cuelga la otra persona.¿a alguno mas le pasa lo mismo?
« Respuesta #5 en: 29 de Mayo de 15, 09:50:04 am »
Hola, a mi me ocurrió eso con un RedMi1S con otra rom, la 5.3.6 o alguna otra de hace tiempo, lo puedes solucionar en plan rápido si seleccionas en las opciones de accesibilidad que el botón de encendido finalice la llamada.
Puedes también hacer el test del cit (o como se llame) del sensor de proximidad y recalibrarlo, al cit entras pulsando varias veces sobre kernel versión en la información del teléfono en ajustes...
« Última modificación: 29 de Mayo de 15, 10:36:57 am por rodolfoiglesias »
« Respuesta #6 en: 29 de Mayo de 15, 13:08:30 pm »
otro fallo, la cámara saca 1 foto y luego sale error de camara,no se puede acceder a la camara
« Respuesta #7 en: 29 de Mayo de 15, 23:06:08 pm »
Pues a mi no me pasa ni lo del sensor de proximidad,  ni lo de la cámara (pues anda que no he hecho fotos ya,  y ningún fallo)... Revisa los wipes, la instalación o la restauración de los Backup...yo hice una instalación limpia y la ROM va de lujo,  de las mejores... Sin fallos ni FC de momento...
« Última modificación: 29 de Mayo de 15, 23:08:18 pm por hawaian »
« Respuesta #8 en: 30 de Mayo de 15, 09:51:36 am »
De las mejorcitas que he probado. Veo que se ha eliminado la animación de carga de la Home después de desbloquear. Cierto que la camara dio error poco después de instalar pero entrando en recovery y haciendo wipe cache de nuevo se solociono (es problema de haber instalado sobre un wipe cache solo) por lo demás creo que la mas fluida que he tenido. Esto va mejorando!!!! Mil gracias
« Respuesta #9 en: 30 de Mayo de 15, 10:40:15 am »
chicos ya todo perfecto con el wipe cache y con el recalibrado del sensor,gracias!!!!!
Desconectado jokerspider
« Respuesta #10 en: 31 de Mayo de 15, 12:01:33 pm »
Todo ok con wipe cache después de instalar. Desde 6,5,1
 Enviado desde mi HM NOTE 1LTE usando MiCenter
Desconectado ramigu
  • 28
« Respuesta #11 en: 31 de Mayo de 15, 15:34:51 pm »
Esta rom va de lujo.., :P
« Respuesta #12 en: 31 de Mayo de 15, 19:55:44 pm »
me gustaria que la camara de video tuviera slow motion.ya que tiene camara rapida que tenga camara lenta,no opinais lo mismo??
Desconectado alsagas
  • 16
« Respuesta #13 en: 01 de Junio de 15, 19:49:11 pm »
Hola a todos. Llevo 24 horas con la room y de momento parece que va bien. Tan solo tengo un pequeño problema que consiste en que mi operadora no sale en el panel de notificacion que deberia aparecer como Lowi cosa que si me ocurria con la anterior room. Por el contrario me aparece Vodafone y no consigo que aparezca mi actual operadora aunque se que lowi utiliza la cobertura Vodafone.
Desconectado KAT3RINA
  • 21
« Respuesta #14 en: 04 de Junio de 15, 22:13:41 pm »
Seria posible obtener la aplicacion de la camara miui, para la pacman? es q me gusta más.
