[ROM] [MIUI6][4.4][v5.5.22][OFICIAL] Xiaomi MI2A - Codename: (taurus)
« en: 27 de Mayo de 15, 07:23:46 am »
AVISO
RECORDATORIOS
Cómo activar Google Now
INSTALACIÓN DE LA ROM
Esta rom debe instalarse con un CWM actualizado por ejemplo el CWM Recovery de Ivan > [TUTORIAL-Mi2A] Instalación CWM Recovery : No tienes permisos para ver los enlaces. Regístrate o Inicia sesión
PASOS A SEGUIR:
  • Nos descargamos la ROM.
  • Iniciamos CWM Recovery
Re:[MIUI6][4.4][v5.5.22][OFICIAL] Xiaomi MI2A - Codename: (taurus)
« Respuesta #1 en: 27 de Mayo de 15, 07:25:55 am »
Changelog 5.5.22 (No tienes permisos para ver los enlaces. Regístrate o Inicia sesión)
[System]
Fix - Charging notification light did not work (05-21)
[Phone]
New - If a call from a unknown number is hung up shortly after it is taken, a prompt will show to ask if you would like to report that number (05-20)
[Contacts]
Fix - Lagging/ FC errors when importing or deleting SIM card contacts (05-21)
Fix - FC error caused by using single quotation marks when searching (05-21)
[Messaging]
Fix - Mi Band 'Vibrate for notifications' feature did not work after receiving a MMS (05-20)
Fix - Messaging app would stop responding if there were too many receipts when sending group messages (05-20)
[Lockscreen, Status Bar, Notification Bar]
New - Added hotspot icon in status bar when portable hotspot is enabled (05-19)
New - Added charging icon in status bar (05-19)
New - Support displaying virtual network operators' names (05-19)
Optimization - Optimized status bar icons' color contrast (05-20)
[Themes]
Fix - No response after booting up for some Redmi devices (05-20)
[Gallery]
New - Added video album to help manage all videos on your device (05-21)
Optimization - Loading speed when opening large images in cloud albums (05-21)
Optimization - Reduced RAM usage when viewing large images (05-21)
Optimization - Enhanced speed of entering Gallery from Camera (05-21)
Optimization - Enhanced smoothness when scrolling in front page (05-21)
Optimization - Loading speed of Offline page (05-21)
Optimization - Modified setting password icon in secret album page (05-21)
Fix - Random FC errors when viewing images in start page (05-19)
Fix - Layout error when choosing several images to add to cloud albums (Mi Note) (05-21)
Fix - Gallery had a high CPU occupancy after booting up (05-21)
Fix - Sometimes, deleting offline albums caused FC error (05-21)
[Weather]
Fix - Sometimes, weather animations displayed abnormally (05-19)
[Settings]
New - Added transition animation when connecting WiFi (05-21)
Fix - Sometimes, incorrect WiFi password prompt did not show after a long time (05-21)
[Market]
New - Brand new MIUI App store (05-18)
New - Most installed app is list first in searching result page (05-18)
Optimization - Optimized searching result page UI style in special situations (05-18)
Optimization - Optimized the prompt when failed to install some apps due to lack of system module (05-20)
Fix - Sometimes Feedback page had FC error (05-18)
[File Explorer]
Fix - Lagging issue when loading thumbnails (05-21)
[Clock / Calculator]
Fix - UI display error when using large font (05-19)
[Mi Cloud]
New - Alarm clock settings can be restored from Mi Cloud when switching to new devices (05-19)
New - New Mi Cloud membership system. Allow users to choose from three membership levels (05-20)
Optimization - Optimized Mi Cloud settings page (05-19)
INSTALACIÓN AVISO
  • Si vienes de una versión anterior a la 5.4.17, es TOTALMENTE necesario hacer WIPE ALL DATA, o sea instalación nueva. (No es recomendable restaurar backup de system, puede dar problemas.)
  • Si vienes de la versión  5.4.17 o posterior, solo con hacer un WIPE CACHE, valdría.
Cambios respecto a la versión anterior
  • Corregidas varias traducciones
  • Se han añadido nuevos iconos meyoueye
« Respuesta #2 en: 27 de Mayo de 15, 07:26:42 am »
MD5: 3ddb70ecbcc8815d9385c5cc1750b568
Desconectado iturrospe
« Respuesta #3 en: 29 de Mayo de 15, 07:54:48 am »
Instalada,  a ver que tal.
 Enviado desde mi MI 2A usando MiCenter
Desconectado isidrofm
« Respuesta #4 en: 29 de Mayo de 15, 08:52:24 am »
Instalada también. A ver si mejora.
Tenía la 5.4.24 con algún FC de vez en cuando, sin poder ubicar Clima (aún haciendo todo lo que por aquí se ha puesto), y perdiéndome cobertura y pidiendo PIN bastantes veces (al final quité el PIN)
De momento, sin teclado ni opción para activarlo. Toca descargar a mano una apk para instalarlo.
Descargada apk de teclado de Google. Activado desde ajustes, y funcionando sin problemas. Luego actualizado desde el Play Store.
Clima. De primeras no localiza. Pide darle permisos al Clima para usar el servicio de ubicación, pero (al menos yo no veo forma) no hay manera de dárselos. Tocará poner el fix que había por aquí, a ver qué pasa
Tras instalar el FIX ya da la opción de ubicar y aparece en los permisos de ubicación, pero al tratar de ubicar no localiza.
PIN. Vuelvo a activar la seguridad de bloqueo PIN, para ver si continúa igual que antes o no.
Tras unas horas de uso ha vuelto ha salir el PIN, así que lo vuelvo a quitar y ya está.
Hora. No sale bien por defecto. Desactivando la zona horaria automática y poniendo Amsterdam/Berlín +02:00, funciona bien, tanto en widget, como en barra y en pantalla de bloqueo.
« Última modificación: 29 de Mayo de 15, 19:24:24 pm por isidrofm »
« Respuesta #5 en: 29 de Mayo de 15, 09:20:07 am »
Yo también quite el pin hace meses ya,  es un puntazo el icono de la brujula
